TwinTurbo.NET: Nissan 300ZX forum - If your engine is running well OEM cats should be sufficient
YlwPrlZTT
on February 11, 2014 at 8:32 AM
just ask a local guy if you can borrow his cats for one day
posted by Stanky
on February 11, 2014 at 01:42 AM
Just did smog in CA where the standards are rediculous and it wasn't even close to failing. Great numbers all around. Make sure you get them nice and hot before you do the test, drive on the highway a little at higher speed to warm them up well.
Cat recommendations
Coldfusown
15:37:24 02/10/14
Stanky
01:42:26 02/11/14
If your engine is running well OEM cats should be sufficient -
YlwPrlZTT
08:32:44 02/11/14
Re: just ask a local guy if you can borrow his cats for one day
The Devils Z
06:12:10 02/14/14
you could drop ign timing back to 10 to 13 degrees
BarryGZX
12:16:35 02/11/14
